[ICEM] 2D quad/tri mesh
Old   January 7, 2015, 17:53
Default 2D quad/tri mesh
ad
adi.ptb is on a distinguished road
Hi guys i want too simulate a compressor piston system with dynamic meshing both smoothing and remeshing methods so i need to use hybrid mesh,say i have a simple square box that half of it meshed with quad and the rest with tri mesh,i used this approach first i created a block and split the block into 2 blocks then i deleted one of the blocks and mesh the other blocks with quad mesh,then i used surface meshing for the other block,and saved the mesh and load it when icem prompt i select merge, but when i read the mesh in fluent it gives me error,i have problem in merging the meshes i think,can anyone please help me? How can i mesh my geometry with quad/tri mesh?
adi.ptb is offline   Reply With Quote
Old   January 8, 2015, 06:33
ad
I had some progress but stil unable to merge the meshesh,the interior between the to meshes will appear as wall in fluent,can anyone help please?
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
