December 27, 2014, 06:01 |
Fixing holes at the end of a wing
Christian
Rep Power: 13 |
already Fixed
December 27, 2014, 07:02 |
davide basso
Rep Power: 14 |
you should define a "thin cut" with the pressure and the suction side of the airfoil.
In order to the thin cut to work you also need to keep the trailing edge curve in a separate part |
December 27, 2014, 13:30 |
Christian
Rep Power: 13 |
After setting the edge paremeter from 0.2 to 0.01 to 0.001 im still facing those holes and getting even more error messages.
I tried to fix it with the thin cuts approach but somehow this approach couldnt fix the holes aswell. Im wondering if its possible to mesh everything with octree meshing, then delete the volume and after that i remesh the fan with tri elements and after that i would mesh the volume with delauny method. Will this fix my problem? And if i switch the surface meshing of the fan from tri to quad elements then my quality looks like this. will this be a problem in cfx? |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
