[ANSYS Meshing] Transformation of refined unstructured meshes
Old   December 17, 2014, 15:36
Default Transformation of refined unstructured meshes - ICEM
Bastian
bastian173 is on a distinguished road
Hi all
for a DES/LES simulation (solver fluent) of a rib-roughened, squared channel with 30 ribs I need to refine the corresponding mesh at some (repeating) regions. For the meshing, only a part of the channel with one rib element should be generated (blocked, premesh …) and then extruded by transforming the unstructured mesh. The mesh consist of hexa elements. Without refinement it works well. With refinement there occurs problems due to the "hanging nodes / non manifold vertex".
For Meshing I use ICEM
Some ideas for handling the transformation of refined unstructured meshes? Would be great…Thanks.
bastian173 is offline   Reply With Quote
fluent, icem, meshing 3d
Velocity/pressure/Temperature blow-up while dealing with unstructured meshes psosnows OpenFOAM Bugs 4 October 19, 2011 16:48
Merge 2 unstructured meshes vinc ANSYS Meshing & Geometry 0 May 19, 2011 17:14
structured vs unstructured hexahedral meshes Usman FLUENT 0 January 19, 2008 05:20
Structure vs unstructured meshes Des Aubery Main CFD Forum 2 July 26, 2003 00:11
Higher Order FV Schemes for unstructured meshes Apurva Shukla Main CFD Forum 4 December 15, 2000 10:17
