[ICEM] Improve Quality of Tetra Mesh
Old   December 10, 2014, 12:03
Default Improve Quality of Tetra Mesh
geod is on a distinguished road
Hi all,
I've created myself an unstructured mesh using tetra/mixed type. Now I'm trying to improve the quality of the mesh. I managed to increase the quality by about 0.1 by smoothing globally, however the quality is still pretty poor.
Now I'm trying to find a way to improve further, but am struggling quite a bit. Could anyone suggest any ways I could go about doing this?
Here are a couple photos of the mesh:
Help would be much appreciated!
geod is offline   Reply With Quote
Old   December 10, 2014, 12:17
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
refine a little bit more ... depending on what you are simulating
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 10, 2014, 12:22
Can you recommend how to go about refining it more? I have just improved by another 0.05 by increasing the density of mesh and smoothing again.
Old   December 10, 2014, 12:23
I am simulating heat transfer between hot water pipe (inner pipe) and cold water pipe (outer pipe)
Old   December 11, 2014, 05:54
From the tutorials I have access to none of them actually explain unstructured mesh refinement. I know I must use the edit mesh section but what tools to use I do not know. I have tried playing around with different things for hours but cannot find the correct way.
Please could someone help!
Old   December 11, 2014, 09:53
diamondx's Avatar
Ghazlani M. Ali
Just decrease the size. local refinement are done by using the density option.
Regards,
Ali
Old   December 12, 2014, 08:45
Excuse my amateurness, but I have tried decreasing maximum size of all the parts and changing density but the quality seems to remain the same.
When you say 'just decrease the size', please could you explain what area to decrease?
Old   December 12, 2014, 09:52
diamondx's Avatar
Ghazlani M. Ali
If you decrease the size and nothing change, it means the size element is still big. You should take a look at the scaling of your geometry. Use the ruler and measure the distance between two points. then you will decide based on that distance. When I say decrease the size, it's in the global mesh paramaters. make sure you click on apply and then go too compute mesh. this is explained in the tutorials. You should start by the tutorials.
Regards,
Ali
Old   December 12, 2014, 10:14
davide basso
rolloblues is on a distinguished road
Hi geod,
I think you're quality is not so bad at all. The problem with your mesh is that it is extremely coarse.
another thing: if you are interested in thermal exchange between the tubes you'll need a prism layer of some sort on both the inner and the outer surface
rolloblues is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[Other] Using mesquiteMotionSolver to improve mesh quality. icaroaccordi OpenFOAM Meshing & Mesh Conversion 0 August 6, 2014 09:59
[ICEM] mesh in-dependency and mesh quality control sujay ANSYS Meshing & Geometry 0 February 20, 2013 03:06
[ICEM] how to improve mesh quality around sharp edge? foolboy007 ANSYS Meshing & Geometry 1 January 23, 2013 12:57
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
