[ANSYS Meshing] Cut Plane Problem
Old   December 4, 2014, 16:54
Default Cut Plane Problem
Joe
cfdizzle is on a distinguished road
Hi all
How do you extend a Cut Plane in ICEM Meshing? The cut plane is only one element thick, I wish to extend this plane
For example I made a cut plane half way down a pipe, how do I extend this cut plane towards inlet?
I have attached pictures if my question is unclear.
thanks
cfdizzle is offline   Reply With Quote
Problem with mixing plane for rotor-stator simulation Frukk FLUENT 0 September 24, 2013 10:47
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
Problem with mpirun with OpenFOAM jiejie OpenFOAM 3 July 7, 2010 20:30
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
mixing plane problem ravindra bankar FLUENT 0 April 29, 2006 06:02
