December 1, 2014, 21:27 |
Creating body on hollow pin fins HS
Rep Power: 12 |
I am trying to create 2 body (solid and fluid) for this heat sink in the attachment. The pin fins are hollow in the center and this create problem in the fluent, the pin fin adjacent cell zone is associated with the fluid region. Any advice on how to create body in this kind of problem?
December 2, 2014, 11:43 |
Ghazlani M. Ali
Rep Power: 29 |
you have 23 pins, create 23 solid bodies inside, make sure they are separated from the fluid body. don't forget to check internal wall in the part mesh section for the walls of the pins. that's it
December 2, 2014, 21:40 |
#3 | |
Rep Power: 12 |
okay, I tried to compare between using and not using internal wall. When internal wall was used, fluent created fin:002 in the boundary condition, it didn't happen when i'm not using internal wall. Last edited by nse.nico; December 2, 2014 at 23:01. |
December 3, 2014, 15:15 |
ahmetcem
how can you create 23 body from this heatsink ? I have same problem that I create heatsink via Catia and export the geometry in design modeler as 1 body. how can I describe all these fins as a independent body ?
December 3, 2014, 20:53 |
Rep Power: 12 |
hole |
Heat Sink Meshing | Olds88 | Pointwise & Gridgen | 15 | December 13, 2024 08:29 |
Creating named selections on inside body surfaces | lbergmann | CFX | 7 | April 11, 2014 18:19 |
[Other] Creating Mesh for double body | tw002 | OpenFOAM Meshing & Mesh Conversion | 0 | February 17, 2014 17:16 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
creating a solid body in Design Modeller | Dan | CFX | 0 | May 24, 2004 12:59 |
