[ICEM] problems with spacing of edges using splines in icem cfd |
November 25, 2014, 03:48 |
M S
Rep Power: 11 |
Hallo,
this is my first post in this forum so hallo @all! I am currently working on an o-mesh in icem cfd and there is a still unsolved problem with the spacing which you can see in the screenshot that I added to this post: the spacing that I created on one edge usind a spline is not growing monotonically on this edge (like it should according to the used spline). The distance between two nodes varies and decreases the quality of the resulting mesh (which is unsmooth because of that). You can see this effect on the screenshot on other parts of the geometrie where I use other splines it is even stronger. Does anyone of you know this problem or know how it can be solved? Thanks in advance and greetings, Michael |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 03:42 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
Spacing value in ICEM CFD | avi031 | ANSYS Meshing & Geometry | 5 | July 22, 2013 13:47 |
Delete block edges in ICEM CFD | YK | CFX | 1 | June 22, 2008 14:30 |
