[ANSYS Meshing] Airfoil Meshing Pinch Control Tolerance |
November 17, 2014, 09:00 |
Diego Garcia Pardo
Rep Power: 12 |
Hi all,
Anyone has had this problem before? "At least one pinch control has tolerance below one or several scoped size control. Reduce tolerance or remove any pinch control in close proximity with of any of such scoped size controls" I have tried to reduce pinch tolerance but it doesn't work. I attach a screen capture. I would like to make the mesh more uniform over the upper side of the airfoil. Thanks |
January 19, 2015, 10:51 |
Rep Power: 12 |
Hi, I have the same problem, did you fix it?
February 24, 2015, 19:35 |
Rep Power: 12 |
I have had this same issue as well. When I import the mesh into Fluent it results in ridiculous numbers for the lift and drag coefficients on my airfoil. My y+ values are correct for my turbulence model. I'm assuming this pinch issue might be causing this.
Has anyone found a solution to this? I'm getting really annoyed using Ansys Meshing. I have found it easier to use then ICEM in many ways but I might just suck it up and figure out ICEM if it gives me a better mesh. If anybody has a solution to this or any input on the problem please let me know. I have attached some pictures of my mesh. |
February 24, 2015, 19:45 |
Not solution, but WorkAround
Diego Garcia Pardo
Rep Power: 12 |
Hi!
I manage to workaround the problem by creating surfaces splits. I made the original cad with solidworks, So I just splitted the surfaces in solidworks and then import them back into Ansys. This however is a really tedious process. Recently I've been able to see that unstructured grids give less trouble when meshing, even though as it is well known, the loss of control over the mesh usually means that the control volumes are not perpendicular to the flow field thus tending to increase numerical error. Ansys mesh is simply not the best tool to mesh, but I haven't found any way better so far. I can't help much more, I am quite a beginner in this world. |
June 8, 2015, 14:36 |
starker
Rep Power: 11 |
anyone know how to solve this problem?
April 30, 2016, 03:46 |
January 16, 2019, 19:12 |
#7 | |
Ali
thank you in advance. |
2-d, airfoil, meshing, pinch |
Dynamic meshing of oscillating airfoil (2d) | abhiramBA | FLUENT | 8 | March 8, 2017 14:49 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 08:04 |
Multi-element airfoil meshing | jose antonio | ANSYS Meshing & Geometry | 2 | June 28, 2011 06:25 |
[mesh tool] meshing airfoil naca 0015 | peter pan | ANSYS Meshing & Geometry | 0 | June 15, 2011 10:26 |
meshing a Naca 4412 airfoil - help | Santiago Orrego. | CFX | 3 | December 18, 2006 05:42 |
