[DesignModeler] How to change AoA of 3D wing? |
November 6, 2014, 10:29 |
Mark
Rep Power: 11 |
I'm working on a 3D kite in Fluent. I've run a complete simulation & I'm happy with the results ie mesh, physics etc. How do I go about changing the 'Angle of Attack', ranging from 0-15 degrees? Can you explain in step-by-step terms, as I'm pretty new to ANSYS. Thanks in advance... |
November 7, 2014, 02:23 |
#2 | |
Amin
Rep Power: 15 |
Usually for changing AoA in fluent simulation, geometry and grid fix and just we change the flow field components in boundary conditions of fluent! |
November 7, 2014, 17:02 |
Mark
Rep Power: 11 |
Thanks for your response. Do you mean that instead of changing the angle of the wing, the angle of the oncoming flow can be changed? So I have to convert AoA into X-Y vectors? |
November 8, 2014, 01:40 |
Amin
Rep Power: 15 |
3d wing, angle of attack, designmodeler, fluent 14.0 |
3D Wing Analysis | Ed | FLUENT | 5 | April 13, 2019 13:07 |
3D Wing Analysis | Ed | FLUENT | 13 | July 26, 2014 05:12 |
How to change turbulence model in InterFoam | Gildeh | OpenFOAM Running, Solving & CFD | 4 | March 28, 2012 12:04 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Delta Wing Structured Grid | Riaan | FLUENT | 3 | December 31, 2004 12:03 |
