[DesignModeler] Overlapping faces 2D
Old   November 5, 2014, 12:06
Default Overlapping faces 2D
herrolsen is on a distinguished road
Sorry if this has been answered before, but I tried googling with no success. I am making a 2D model and I need to have different faces in order to set different mesh parameters in different areas.
I drew one main sketch and added two sketches on top where I wanted, added the two extras as frozen and used boolean subtract to remove the excess part from the main surface.
My problem arises when I use subtract on a curved surface, I end up with two lines instead of a shared. I also tried to use connect, but with no success.
Can anybody help me out?
herrolsen is offline   Reply With Quote
Old   November 5, 2014, 17:28
Solved!
Just had to make a sketch for each individual part (by copying lines from the other sketches so that they would match up perfectly). Then make surface from sketch, add all sketches as geometry, choose add frozen. After making the surfaces I used boolean-subtract to make individual bodies without overlapping.
face, overlap
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
