[ANSYS Meshing] meshing a fluid/solid what's the best format to import the geometry
Old   October 29, 2014, 22:47
Default meshing a fluid/solid what's the best format to import the geometry
steve
zytra is on a distinguished road
Hi
I've got a geometry composed a solid and 2 fluids.
I'm experiencing with different size geometries and once in a while I would have problems generating a (conformal?) mesh - well it does generate but can't be exported to fluent.
So far the best technique has been to export my SolidWorks assembly (3 parts) into a STEP file which I import in workbench.
DesignModeler imports 3 bodies.
It doesn't work all on the time though.
What are you guys doing to prevent issues with improper mesh?
Thanks
Steve
zytra is offline   Reply With Quote
Old   October 30, 2014, 11:47
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hey
What is your problem exactly? CAD format for import to ANSYS? If you use solidworks, you can import directly with sldprt format to ansys
amin.z is offline   Reply With Quote
Old   October 30, 2014, 20:38
steve
Thanks for the response, Amin
I know I can import many different format including native SW files.
I noticed that depending on the file format that I am using, the interface surfaces will sometimes cause overlapping issues when exporting the mesh through workbench. And I also noticed that sometimes Fluent would identify interfaces, creating mating shadow zones, sometimes it won't.
I have had the best results importing STEP files and creating a multibody part from the bodies in DesignModeler.
However it still doesn't always work so I am wondering what you guys are doing when working with multiple 3D solid/fluids.
Thanks
Steve
Old   October 31, 2014, 02:06
amin.z's Avatar
Amin
I've experienced the same problem
I suggest you:
1. Import your CAD as sldprt format! sometimes STEP/STP format gives small changes in model dimensions and cause overlapping and...
2. If it's possible, use boolean for ensure that interfaces and... be OK!
3. sometimes fluent doesn't know mesh interfaces! so you should use connection in ansys meshing for model interfaces!
[GAMBIT] Need advice on meshing technique to be used for this geometry ankur_kr ANSYS Meshing & Geometry 12 March 24, 2014 01:31
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 05:25
[ICEM] Best way to import geometry ICEM Cottbus ANSYS Meshing & Geometry 4 June 12, 2012 10:42
[DesignModeler] Import external geometry problem Houman ANSYS Meshing & Geometry 0 May 16, 2012 05:24
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
