October 29, 2014, 07:34 |
Icem 2:3 refinement
I'm currently generating a block hexahedral mesh for OpenFOAM using ICEM (via Fluent format). Thereto i would like to produce a 2:3-Refinement between adjacent blocks like this: |__|__|__| |__|__|__| |___|___| |___|___| However if I e.g. use a horizontal resolution of 6 cells and set a 1/2 refinement for the first and a 1/3 refinement for the second block, no premesh is shown after recomputing. Thus I wonder if there is a possibility to get this working. Regards Alexander |
icem, refinement |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer | Sunxing | OpenFOAM Meshing & Mesh Conversion | 9 | September 20, 2014 09:30 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
