[ANSYS Meshing] meshin the interface between two domains
Old   October 20, 2014, 11:28
Default meshin the interface between two domains
Ema40 is on a distinguished road
Hi everybody.
I have to simulate a water wheel inside a channel. I have a question and I hope someone will answer me.
1) I have two adjacent static domains with different mesh size
In the meshing (the default mesh application in Ansys), it is possible to create on the respective adjacent interfaces the same mesh, in order to have a perfect correspondence? I have already attribuite at the two adjacent surfaces the same mesh size (with the option Face sizing), but, event the cells have the same dimension, they don't match.
Very thanks
Ema40 is offline   Reply With Quote
Old   October 21, 2014, 06:13
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hello Ema,
You can use the "contact sizing" option in Ansys Meshing. In the Project outline tree under Connection> Contact> Contact Region, then drag and drop your contact interface in the mesh tab and it will create a contact sizing element between your two domains at that interface.
Gweher is offline   Reply With Quote
Old   October 21, 2014, 06:37
hwet is on a distinguished road
you can try as said above, although i always find trouble doing the contact sizing, so i always form one part out of the different parts in design modeler by just selecting them to form a single part and then mesh it, works for me...
hwet is offline   Reply With Quote
Old   October 21, 2014, 10:07
Paritosh Vasava
vasava will become famous soon enough
I would also suggest 'Match Control'.
vasava is offline   Reply With Quote
Old   October 21, 2014, 11:15
Ok.
Thank you very much to all!
domain, mesh interfaces
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
