[ANSYS Meshing] Help Generating Multiple Surfaces as a Multibody in Ansys Fluent |
September 21, 2014, 20:47 |
daniel
Rep Power: 12 |
CFD Friends,
Im trying to create a 2D model of a pipe with cross flow along with a transverse pipe injecting fluid into the main stream. My issue is that I draw multiple sketches which define areas of different mesh densities, but when I "create surfaces from sketch" for each sketch, Fluent combines them all into a single surface, and I am unable to define the individual mesh densities I desire. Does anyone have any suggestions for how I can fix this? Maybe an alternate method? Here is an example of what I mean, http://imgur.com/crGFTGu While these are 4 different surfaces, DM automatically combines them into a single surface, and thus cant control individual mesh quality. Thank you |
September 22, 2014, 03:16 |
Amin
Rep Power: 15 |
I think you don't change "add material" to "add frozen"!
I guess with applying this change, your issue will be solved! |
September 22, 2014, 15:21 |
Perfect!
daniel
Rep Power: 12 |
Thanks. in the "Surfaces from Sketch" I had to change "Operation" from "Add Material" to "Add Frozen". Thus I was able to generate multiple bodies.
2 dimension, mutlibody, surface from sketch |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 18:27 |
