[ANSYS Meshing] I have trouble in meshing the space of a hollow cylinder |
September 5, 2014, 19:40 |
Zhuo
Rep Power: 12 |
when I used workbench of ANSYS,I cannot mesh the space of my stuff. it's like a hollow cylinder(image), after generate mesh, I wanna get the grid inside the cylinder, not only the surface. can anyone told me how to solve it ?
September 9, 2014, 16:37 |
Amin
Rep Power: 15 |
Can you explain more? Do you want to mesh all of the cylinder? The surfaces and inner empty part?
September 9, 2014, 19:37 |
Zhuo
Rep Power: 12 |
September 10, 2014, 00:26 |
Amin
Rep Power: 15 |
Do you fill the inner empty space with material? Is the outer space solid and inner space fluid? As appear in the picture, I think you have only the solid part!
September 13, 2014, 16:02 |
Zhuo
Rep Power: 12 |
Yes, I can ONLY mesh the solid part. I do not know how to mesh the empty space. Do I need to fill the empty space with material? Cuz it is an empty space. In other words, the material is air.
September 14, 2014, 08:02 |
#6 | |
Amin
Rep Power: 15 |
If you want to do a cfd simulation the air must exist and meshed But if you want to do a static analys you don't need air! |
September 23, 2014, 22:21 |
Rep Power: 13 |
old times, i used to have this problem long ago when i was new to cfd. any place you want to mesh must be filled. if you fill the inner space with material only then it would be meshed, (which makes sense as well) the wall will be the outside surface, any place which you dont want to mesh or you want it to act as a wall, take out the material from that space. hope i make sense.
mesh 3d |
[ANSYS Meshing] Meshing a Cylinder | anuprdk | ANSYS Meshing & Geometry | 3 | December 9, 2014 13:32 |
[GAMBIT] Trouble with meshing Chevron Nozzle | piyushvjn | ANSYS Meshing & Geometry | 0 | May 26, 2014 16:14 |
[ANSYS Meshing] Meshing 3d circular cylinder in ICEM | darazsbence | ANSYS Meshing & Geometry | 0 | March 11, 2014 17:35 |
space between vector/scalar scene and cylinder | namik | STAR-CCM+ | 0 | March 20, 2011 10:33 |
[ICEM] (ICEM CFD) meshing over a cylinder | vmlxb6 | ANSYS Meshing & Geometry | 6 | August 11, 2010 15:37 |
