Rep Power: 12 ![]() |
Hi all,
I have a wing in a 3D case for a FSI simulation. To start I want to try separately the fluid part. After having a lot of problems with the 2D model we saw that meshing with ICEM was giving some compatibility issues, so we have to mesh using the Mesh tool on ANSYS Workbench. My first try was to mesh all the domain together, using inflation on the wing surface and edge sizing on the tip and root of the wing, but the results on CFX are not good (I have points with unrealistic high velocity) and residuals do not coverge. I would like to do a C-Mesh around the wing. So I divided the fluid volume in 8 bodies to have control over the edges. The result is in the pictures. I have two main problems: - At the front part it does not look as a C-Mesh at all (I wanted to do something like what is explained here https://confluence.cornell.edu/displ...Airfoil+-+Mesh but in 3D) - When I try to start the CFX simulation I get the message: Application Error in CFX-Pre: ERROR There was a problem importing the mesh from the requested file. The importing process reported the following problem: Model "Model" does not have a valid mesh associated with it. Body B295 is an unsuppressed surface body that does not enclose a volume. Only 3D volume meshes can be imported. If your model contains valid bodies as well as surface bodies then suppress the surface bodies and remesh before continuing. ERROR: Failed to export model. I would also like to add some kind of inflation on the surface of the wing, because it is really important to find the stall point. But the option is not working. I would appreciate any help: how I can do the meshing, if there is any better strategy, why I cannot import the mesh... Thank you! |
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator | Crank-Shaft | ANSYS Meshing & Geometry | 5 | January 17, 2016 23:29 |
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp | Crank-Shaft | ANSYS Meshing & Geometry | 0 | January 11, 2013 05:48 |
[ICEM] Problems with meshing a 3D wing w/winglet | cesarcg | ANSYS Meshing & Geometry | 12 | December 13, 2012 07:59 |
[ICEM] Blocking For Swept Wing | air_engineer_arsenal | ANSYS Meshing & Geometry | 13 | July 24, 2012 11:52 |
3D wing + wind tunnel hexa structured meshing | icemaniac178 | ANSYS Meshing & Geometry | 9 | October 28, 2010 09:37 |
