[ICEM] Surface mesh does not follow node spacing
Old   August 20, 2014, 08:32
Default Surface mesh does not follow node spacing
Robert
findtheinvisiblecow is on a distinguished road
I'm currently working on a surface mesh for an aircraft. Therefore I'm using the same approach as the ICEM tutorial of the DLR F6, "Introduction to ANSYS ICEM CFD, Workshop 3.2: Shell Meshing - Winbody". Please find a link to the tutorial attached:
https://www.dropbox.com/s/xy787ex9xs...body_Shell.pdf
Using this approach, I specify the Node Spacing of the curves to setup the surface mesh. Unfortunately my surface mesh does not always follow this node spacing, resulting in a surface mesh that's quite coarse in critical area's (lots of curvature, important flow locations).
How can I force the surface mesh to follow my node spacing?
I've provided a link to my project file:
https://www.dropbox.com/s/qtocrnglym...0SIMP%20V4.prj
findtheinvisiblecow is offline   Reply With Quote
Old   August 20, 2014, 08:35
Robert
I've also made some screenshots to illustrate the situation, although they might be difficult to understand. The green arrow points to a curve node spacing that is followed by the surface mesh, the red arrows indicate the curve that don't.
https://www.dropbox.com/s/zuj5g01wu0...pacing%201.png
https://www.dropbox.com/s/jj8pbzazps...pacing%202.png
Old   August 20, 2014, 13:49
kad
kad will become famous soon enoughkad will become famous soon enough
Uploading the .prj-file only does not work. We also need .tin, .uns or .blk files.
kad is offline   Reply With Quote
Old   August 20, 2014, 14:10
Robert
Sorry mate, that's right. Here they are:
https://www.dropbox.com/s/zqpuyplsix...0SIMP%20V4.uns
https://www.dropbox.com/s/bf43wif02x...0SIMP%20V4.tin
Old   August 25, 2014, 05:12
Robert
I've been all over my project again, resetting part mesh sizes, surfaces mesh sizing and finally the node spacing again. Not much seems to change. The cells a the front leading edge of the FLAPS and SLATS are still quite coarse and do not follow the surface closely.
Still I am following the exact same steps as in my tutorial:
What am I doing wrong?
Old   August 26, 2014, 10:26
kad
Patch dependent meshing needs a nearly perfect geometry. This means that all curves are attached to their surrounding surfaces. There should not be any single curves. Your model has lots of single curves (yellow), so you need a better topology. You can try the repair topology tool. Sometimes it is helpful to delete all points and curves permanently before using it, but then you have to do curve bunching once again.
If you have your model as a CAD model I would load it into Design Modeler and make one single body out of the whole model (if possible). Then read it in ICEM with workbenchreader.
Old   August 26, 2014, 11:05
Robert
Thanks a lot for pointing this out!
It is a very complex geometry, which indeed had problems with the topology. Since I've downloaded it as a STEP-file that consisted out of 200+ parts, I decided to narrow it down to a few parts and then repair the geometry using 'Build Topology' part-by-part.
In the project posted above I didn't repair the part WING yet, since it gave some problems using 'Build Topology'. Still, I thought that the topologies of parts FLAPS, SLATS, BUMP, FAIRING and FUSELAGE were all right?
What tolerance did you use? I reckon that you've tried repair the entire topology?
Old   August 26, 2014, 12:17
kad
I have made a screenshot with all the options I used for "Build Topology". Then there is one little gap between some slat surfaces. You can easily find this because there is only one yellow line left. I deleted the surfaces and recreated them manually. You can do this before "Build Topology" or you even should do it.
Now other errors should come only from improper mesh sizes/methods. You should be able to sort them out.
icem cfd, node spacing, surface mesh
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 04:26
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
