[ANSYS Meshing] geometric dimensions from mesh
Old   August 19, 2014, 04:15
Default geometric dimensions from mesh
jyothsna k
jyothsna k is on a distinguished road
I have a simple 2D mesh whose geometry file is corrupted. I need to write an UDF and need the dimensions. How do i extract the geometry details from the mesh.
Thanks in advance
jyothsna k is offline   Reply With Quote
Old   August 19, 2014, 05:40
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
In icem cfd :
1. Import that mesh File > Import Mesh > From fluent
2. Edit > Mesh to facets ( do not merge close nodes, for other options click yes or ok)
thats all. You can also export that geometry as parasolid or IGES
You can also recover geometry FE modeler. May be you can also do it in designmodeler but i haven't done it in DM so you need to try ...
Far is offline   Reply With Quote
Old   August 19, 2014, 06:19
jyothsna k
Thank you very much.
geometry, mesh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 04:26
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
