[ANSYS Meshing] Meshing thin surface in Ansys meshing |
August 14, 2014, 16:18 |
Hey all,
I have a pipe, and in this pipe there is a grid of thin surfaces going down it. In Designmodeler, I use a 'fill' on this pipe to get the fluid domain and I have the surface body of the thin grid. I have my wall as a named selection/boundary condition, and the grid as a separate one. After meshing it in Ansys mesher and bringing it into Fluent, the thin surfaces are not there in the boundary condition list. If I set the physics preference to mechanical in the mesher, then Fluent sees them, although I am not doing mechanical . The only way I've managed to do thin surfaces in the past are through some slicing options, e.g. here I could keep slicing by various planes at different offsets to make a grid of fluid volumes, put a named selection on the internal faces, then it recognises it. This way seems tedious and somewhat eccentric however, and there must be an easier way. Thank you for your help. |
August 15, 2014, 12:39 |
Solved. Spoke to Ansys, bug in the slightly older version I am using!
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
[ANSYS Meshing] ANSYS Meshing hangs at "Preparing to model boundary for part" | jonny_b | ANSYS Meshing & Geometry | 12 | June 12, 2012 02:55 |
How To save a created mesh file in Ansys Meshing | ashtonJ | CFX | 4 | January 7, 2012 23:04 |
[ANSYS Meshing] ANSYS Meshing vs GAMBIT | aerospain | ANSYS Meshing & Geometry | 0 | September 28, 2011 07:05 |
How can I set a thin surface in CFX Build4? | laurel | CFX | 2 | July 18, 2002 02:54 |
