[ICEM] negative sector volume
Old   August 9, 2014, 01:24
Default negative sector volume
adam2008 is on a distinguished road
Hi, I ran into a problem that I don't have a good solution.
I generate a very complicated mesh in icem and import to CFX. CFX simulation can run, but always gives a warning like this.
ERROR #002100011 has occurred in subroutine cVolSec. |
| Message: |
| A negative SECTOR volume has been detected. Execution will proceed |
| but this is a possible cause of robustness problems. |
| The location of the first negative volume is reported below. |
| Volume : -0.1090E-11 |
| This warning may be made fatal by setting the expert parameter |
| 'negative volume option = 1'.
I can use the coordinates to find the bad element and fix it manually in ICEM. However, I want to know how many elements have this kind problem before I can go ahead do it. If it is like 10 problematic elements, I can do it. If there are hundreds of problematic elements, I have to figure out some new method to generate mesh.
Looks like CFX only gives you the coordinate information of one problematic element (the FIRST negative volume....). How can I know all of them in one shot?
Also, I found all those problematic elements are flat tets elements. Can I use smoothing function in ICEM to fix them? And which quality parameter should I use, quality, aspect ratio, skew or something else?
Thanks a lot
adam2008 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
