[ANSYS Meshing] How to align nodes in straight (vertical) lines
Old   July 23, 2014, 04:07
Default How to align nodes in straight (vertical) lines
Judith Richter
Judith is on a distinguished road
I am fairly new to ANSYS and just started to set up a simulation to calculate the flow through a (micro) de Laval nozzle. My goal is to post process some boundary layer parameters. That is why I would prefere if the nodes were aligned in straight vertical lines, i.e. that all nodes connected in y direction exhibit the same x coordinate. By default, ICEM proposes a mesh as attached.
Does anybody of you know if ICEM features such a mesh manipulation? So far, I didn't even find a clue how to do so.
Thank you!
Judith is offline   Reply With Quote
Old   July 24, 2014, 08:22
Vimalraj
vimaero is on a distinguished road
Thank you!
is there any particular reason why you want such a grid? You will loose the orthogonality of the grid cells if you create a straight grid lines.
vimaero is offline   Reply With Quote
Old   July 24, 2014, 13:56
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Thank you!
For boundary layer parameters you don't grid to be aligned in y direction (same X location)... And I am sure it is default behaviour of ICEM CFD
Far is offline   Reply With Quote
Old   July 25, 2014, 04:43
Judith Richter
Thank you for your replies, seems like ICEM does not have this option... Looks like I cannot avoid programming a post processing tool to interpolate my boundary layer parameters
Old   July 25, 2014, 05:37
Far
Sijal
Why you want to programm it???. It will automatically give you averaged values on the location you specify...
Old   July 25, 2014, 05:55
Judith Richter
Is there a function in CFX post? As I said I am new to this topic... Thank you
icem, nodes, straight
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
[blockMesh] blockmesh arc, no curves, no arc, only straight lines heavy_user OpenFOAM Meshing & Mesh Conversion 9 January 26, 2017 21:48
Plotting Residuals ata OpenFOAM 12 July 8, 2011 03:50
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
