Erica P
Rep Power: 0 ![]() |
Hi guys,
I am new to CFD, and spent the last one month trying to learn the basics. I am trying to simulate a flow in a closed chamber, where the air is heated by a couple of heating coils. As a first approximation, I just created a thin fluid zone and added an energy source to it in FLUENT (since I did not want to simulate a conjugate heat transfer problem right away with the actual heating coils). However, I am concerned about the fact that since this is a different zone, it is meshed differently than the rest of the fluid domain. My question is: is there a way to have it meshed in the same way as the rest of the fluid domain, and yet be able to 'heat' it up as a separate zone? Sorry if this is elementary, but I couldn't really find an answer on this forum!! Thanks, Erica |
Błażej Popławski
Rep Power: 13 ![]() |
If you are meshing it in Ansys Meshing you have to create one part from all of your domains (Ansys DM -> Geometry -> Pick all parts -> Form New Part) and then it will be meshed as a one part and it will be "separated". If you do not want to create a part from your domains or your're using another mesher you can create Interfaces from walls of your domains which are coincident and then the mass flow through these walls will be modeled by Fluent.
ansys, fluent 15, heating, mesher, zones |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
