[ICEM] Problems meshing an airfoil with ICEM
Old   June 19, 2014, 07:34
Default Problems meshing an airfoil with ICEM
Alberto
Bert9 is on a distinguished road
Iīm trying to do an hexa mesh with ICEM for a compressor blade. In order to do that, I splitted blocks and I used an O-grid block in the center.
As I got the premesh, there were problems with the it in some blocks. I donīt understand them because everytime I try to do it the problem comes in a different block. The block that was wrong last time is now right and so on.
Eventually I managed to do it right (image attached "correct"), but now when I change something (smooth, refinement, move vertex) this problem appears again (images "error 1 and 2").
Does anyone of you know what might cause this problem and how to solve it? I donīt know if itīs a geometry problem or a problem doing the blocking with ICEM.
Thank you for your attention.
Bert9 is offline   Reply With Quote
Old   July 1, 2014, 13:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
r u able to solve problem?
Far is offline   Reply With Quote
Old   July 1, 2014, 14:02
Alberto
Nope. I just tried several times building all up until I finally got the right mesh. Still I can't tell why it went right that time.
Any suggestions where this problem comes from?
Old   July 1, 2014, 14:18
Far
Sijal
common error is due to wrong association.
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 05:25
[ICEM] Wind turbine meshing problems in ICEM luxingzhe ANSYS Meshing & Geometry 0 November 28, 2011 06:55
ICEM tet-tet interface not meshed and problems when meshing in segments Catthan ANSYS Meshing & Geometry 0 October 27, 2011 07:12
