[DesignModeler] accessing a "Design Parameter" in CFX
Old   June 19, 2014, 00:25
Default accessing a "Design Parameter" in CFX
rae
rae is on a distinguished road
Please help me to use the minumum y value of my fluid domain in a CFX Setup container expression. The CEL function "min" just compares two values so I can't put every y of the domain there I don't think.
I could work out the minumum y value using a couple of existing DM Design Parameters but they aren't recognised (when used in a CFX Setup expression) and I don't see any way of making the DM defined Design Parameter global (like you can do with an RMB on a Results expressions for example).
Another alternative would be to have DM use a parameter defined in the CFX Setup container but I don't see how to do that either.
Thank you.
rae is offline   Reply With Quote
geometry, setup, shared parameter
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 03:43
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
PhD using CFX Rui CFX 9 May 28, 2007 06:59
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
