[ANSYS Meshing] Assembly inflation mesh failing for different geometry orientation
Old   June 12, 2014, 09:21
Exclamation Assembly inflation mesh failing for different geometry orientation
Adhikar Hariram
PedFr0 is on a distinguished road
Hi all
I am struggling with generating inflation layers when using the Cut cell method in ansys meshing for a heliostat geometry. I initially meshed the geometry when it was oriented perpendicular to the flow, shown in the attached images, and for this orientation everything worked fine, i.e., no issues with generating inflation layers. However when I orient the heliostat 45 degrees to both the flow and the ground I cannot generate inflation layers on either the ground surface or the heliostat surface. Could anyone please help me in being able to generate the mesh with inflation or at least advise as to why the inflation can only be generated for the first orientation.
*edit* I forgot to mention the version of ansys I am using is 14.5
Thanks in advance.
Adhikar
PedFr0 is offline   Reply With Quote
assembly mesh, cut cell, inflation, meshing failed
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 13:11
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 10:14
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
