[ICEM] Trailing edge meshing problems
Old   June 11, 2014, 13:54
Default Trailing edge meshing problems
Juancho Perez
juanchope is on a distinguished road
Hi!
I'm trying to mesh airfoil with octree algorithm but i'm having troubles to mesh it near the trailing edge, elements does not stick to the edge. Geometry es composed by an upper surface (green), a lower surface (red) and there is a small surface on the trailing edge (blue or purple).
The images show my problem (had problems to attach them as a file)
https://www.dropbox.com/s/o1rrdhpohmt3qq4/img1.jpg
https://www.dropbox.com/s/ng010rl655qqyta/img2.jpg
https://www.dropbox.com/s/lutvumc64t0j5aj/img3.jpg
The last one is as it looks when I import it to fluent, it is easily noticed that there is one (or few) elements missing:
https://www.dropbox.com/s/8m9m63g3mxjvn0w/img4.jpg
As i have read in another post, i tried reducing the edge criterion on the octree algorithm but I can do it only to 0.11, if try to set it lower, degenerated elements start to appear on the meshing process.
Also I tried to reduce my mesh size (by reducing the scale factor) but I come to the same result, degenerated elements during the meshing process.
The same thing for cells in the gap, as soon i set more than 3 cells in the gap, it creates degenerated elements.
Every time it founds degenerated edges the mesh is useless as even the volume inside the airfoil tries to be meshed.
Hope anyone can help me!
Thank you!
juanchope is offline   Reply With Quote
Old   June 19, 2014, 10:04
Yon Han Chong
yonchong is on a distinguished road
Did you try the "thin cut" option.
Global Mesh Setup -> Volume Mesh Parameters -> Define thin cuts.
If you are going to use it read the manual first because you have to have seperate part for two surfaces and the line bordering the surfaces.
Other option is read back the mesh but only surface mesh only.
File -> Mesh -> Open Surface Shell Only
Then manually fix the surface mesh using options in Edit Mesh.
The rebuild the volume mesh using Quick (Delaunay). This is much easier option than try to fix surface and volume cells together.
yonchong is offline   Reply With Quote
Old   June 19, 2014, 22:10
kad
kad will become famous soon enoughkad will become famous soon enough
Define thin cuts is a good guess. I would define a node distribution for the trailing edge curve in "curve mesh setup". Choose a pretty low value for maxsize. You can preview the distribution by activating it via right mouse button on curves in the display tree. Further I would decrease sizes on the wing in general as the mesh looks very coarse.
kad is offline   Reply With Quote
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 11:42
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Trouble with sharp trailing edge Prakash.Paudel ANSYS Meshing & Geometry 4 August 12, 2011 15:01
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 12:58
GAMBIT: Assumption of an edge type while meshing Agnes FLUENT 0 June 22, 2005 14:37
