June 1, 2014, 10:28 |
Icem 2d mesh over airfoil & cfx
Sandeep
Rep Power: 14 |
i have created a good quality (>0.3) 2d mesh over an airfoil in icem by making use of curve and surface controls
then i saved it as .msh file and opened it in CFX keeping the 'advanced options' on extruded it 1mm along the cell thickness direction given the BC's and then run the CFX solver ...but what i found in that it fails to start showing "floating point excpetion/ zero division" error then second time i enabled the "double precision" option in the solution manager and found that the solution is running fine my question is : what are the causes of such a error and how to prevent it ? (i had just enabled "double precision" as a hit and trial approach ) |
June 2, 2014, 06:01 |
Germany
Rep Power: 12 |
Hi Far,
i have attached my pictures did you see it ?, i could mesh it by blocks but the geomety is very complex when i open it after converting by fluent solver in icem, fluent can open the mesh file but it said there are many problems in your mesh file, could you please help me. can i send you the tetin files to see where the problem is |
simulating 2D airfoil mesh in CFX | iffy | ANSYS Meshing & Geometry | 7 | January 24, 2017 04:05 |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 04:42 |
[ANSYS Meshing] Question about ICEM mesh output to CFX | lnk | ANSYS Meshing & Geometry | 0 | July 27, 2012 16:39 |
ICEM CFD to CFX geometry and mesh | Luca | CFX | 6 | February 4, 2010 17:31 |
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! | Vu Trinh Tuan | CFX | 11 | March 28, 2005 20:04 |
