May 17, 2014, 16:28 |
An Interesting Blocking Issue
Andy
Hi all,
I'm relatively new to ICEM and am in need of some help. I'm attempting to block out a moderately complex part so that I can produce a replay script and run a parametric study on a range of geometries. The part is cyclically symmetric, so cut into thirds it looks like this: I've been having decent success thus far getting the blocks/premesh to associate to the complex geometry/fillets: I've been using block splits and a spline edge split on the upper edges to sculpt all this out. The issue I keep running into is that when I try to add nodes radially (so that I don't have these massive pizza-slice elements) everything explodes: 3 nodes 10 nodes Here's a couple pics of my current blocking: I've been trying a variety of approaches--I tried edge-splitting the edges that should be associated with the inner and outer radii to make them match up, which just caused more trouble. Associating the edges that I think should connect to the outer radius causes similar issues. Any tips on how I can block this out? Am I approaching this in the wrong way entirely, or am I just missing something vital? By the way, a lot of my strategy here is coming from Simon's elbow tutorial and this one, (which I think is by Far? http://www.youtube.com/watch?v=roZNUbhFVJ0) Feel free to let me know if any more info is needed to tackle this problem. Thanks, Andy |
May 23, 2014, 09:46 |
Sebastian Engel
Rep Power: 21 |
Are you sure about the associations of the edges marked in the following picture?
FOGORnr.png It seems to me, those edges needs to be associated to the outer radius's edges or surfaces. The arrows seem to indicate, that right now, those edges are projected to the inner radius. |
May 23, 2014, 12:26 |
Andy
I've addressed that, actually; associating those edges to the outer surface pretty much immediately results in the pre-mesh skewing beyond recognition. I've managed to solve the issue, though--I just created another part out of that negative space that I was trying to fill, and called that the fluid. Meshed up beautifully.
Currently just trying to get FLUENT to export XY data in something other than SI units, which is apparently impossible -.- |
associations, blocking, icem, meshing |
[ICEM] Problem to load the blocking | biasilveira | ANSYS Meshing & Geometry | 2 | February 24, 2013 22:04 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
VOF- Interesting issue | Dave | FLUENT | 0 | December 18, 2000 17:49 |
