[DesignModeler] Inaccurate drawing of Airfoil using 3d curve concept |
Ajit Menezes
Rep Power: 0 ![]() |
Hi, I'm new here, and new to using Ansys Workbench as well. I have tried to import a NACA4412 airfoil on the DesignModeller section using the 3D curve function and a .txt file (coordinates.txt, attached below). However, the curve generated has a few bumps and straight lines, and I am unsure of how to rectify it. Image of the issue in PDF is also attached below.
Would be really grateful for some help! Sorry if the question may be abit amateurish.... |
Kevin Hoopes
Rep Power: 16 ![]() |
Worked just fine for me. Granted I am using 15.0
turan
Rep Power: 12 ![]() |
khoopes why this airfoil is open at the sharp end,how can I closed ? my problem is different,when I choose
Concepts-Surface form Edges I get this error Some selected edges failed to form closed loops I am using this amazing site https://confluence.cornell.edu/displ...oil+-+Geometry here is my airfoil 1 1 1,00000 0,00021 0,00000 1 2 0,95053 0,01028 0,00000 1 3 0,90104 0,02038 0,00000 1 4 0,85148 0,03018 0,00000 1 5 0,80151 0,03967 0,00000 1 6 0,75126 0,04780 0,00000 1 7 0,70108 0,05480 0,00000 1 8 0,65085 0,06106 0,00000 1 9 0,60057 0,06624 0,00000 1 10 0,55025 0,07040 0,00000 1 11 0,49989 0,07344 0,00000 1 12 0,44950 0,07522 0,00000 1 13 0,39910 0,07552 0,00000 1 14 0,34871 0,07414 0,00000 1 15 0,29834 0,07131 0,00000 1 16 0,24800 0,06705 0,00000 1 17 0,19770 0,06126 0,00000 1 18 0,14748 0,05366 0,00000 1 19 0,09737 0,04380 0,00000 1 20 0,07230 0,03865 0,00000 1 21 0,04749 0,03034 0,00000 1 22 0,02276 0,02095 0,00000 1 23 0,01059 0,01451 0,00000 1 24 0,00582 0,01112 0,00000 1 25 0,00350 0,00902 0,00000 1 26 0,00000 0,00000 0,00000 1 27 0,00650 -0,00678 0,00000 1 28 0,00918 -0,00796 0,00000 1 29 0,01441 -0,00969 0,00000 1 30 0,02724 -0,01251 0,00000 1 31 0,05251 -0,01592 0,00000 1 32 0,07770 -0,01919 0,00000 1 33 0,10263 -0,01996 0,00000 1 34 0,15252 -0,02244 0,00000 1 35 0,20230 -0,02406 0,00000 1 36 0,25200 -0,02499 0,00000 1 37 0,30166 -0,02537 0,00000 1 38 0,35129 -0,02518 0,00000 1 39 0,40090 -0,02436 0,00000 1 40 0,45050 -0,02266 0,00000 1 41 0,50011 -0,02024 0,00000 1 42 0,54975 -0,01736 0,00000 1 43 0,59943 -0,01418 0,00000 1 44 0,64915 -0,01086 0,00000 1 45 0,69892 -0,00760 0,00000 1 46 0,74874 -0,00460 0,00000 1 47 0,79849 -0,00229 0,00000 1 48 0,84852 -0,00132 0,00000 1 49 0,89896 -0,00076 0,00000 1 50 0,94947 -0,00048 0,00000 1 51 1,00000 -0,00021 0,00000 |
turan
when I change firts and last line
1 1 1,00000 0,00000 0,00000 and last line 1 0 its closed,probably results will be effected but this small change can be negligible,isnt it? |
3d curve, airfoil, ansys, design modeller |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
[ICEM] 2D Airfoil Patch Dependent Mesher Ignores Curve Sizing | khoopes | ANSYS Meshing & Geometry | 0 | February 2, 2013 10:28 |
airfoil drawing in ansys workbench | Hammam | ANSYS Meshing & Geometry | 2 | June 18, 2011 19:34 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
