[ICEM] How to disconnect the mesh density on two sides of a Y junction
Old   May 15, 2014, 15:59
Question How to disconnect the mesh density on two sides of a Y junction
Augusto Fontan
Fontan is on a distinguished road
I understand this may be a simple issue, but I'm still a beginner in ICEM and haven't managed to find a solution in the forums.
I have a mesh for a scramjet engine which, at a certain point, splits at the cowl so the compressed airflow goes through the isolator and the free-stream flow passes under the cowl, similar to a Y-junction, as in the picture.
Thing is, blocks 21 and 14 are connected through the VORFN block 27, so that the number of cell nodes in the x-direction is the same for both blocks. Is there a way to disconnect these blocks so I can have a different number of cells in the x-direction for each? Deleting the VORFN block is not an option, as it just gets recreated.
Thanks for the help.
Fontan is offline   Reply With Quote
Old   May 15, 2014, 21:08
kad
kad will become famous soon enoughkad will become famous soon enough
When deleting the block check the option "delete permanently". This should disconnect them.
kad is offline   Reply With Quote
Old   May 22, 2014, 09:54
Augusto Fontan
It seems to disconnect them, but it completely distorts the remaining blocks downstream, which in turn seems to distort the mesh.
I wonder if there is another way to do it?
blocking, blocks, icem cfd 14.5, scramjet
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Mirror Mesh | Delete duplicate mesh pythag0ra5 ANSYS Meshing & Geometry 6 November 19, 2013 08:35
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
