[ICEM] Problem: Ogrid outside the block
Old   May 14, 2014, 19:42
Default Problem: Ogrid outside the block
Fred_Erik is on a distinguished road
Hello everybody,
I want to create an Ogrid in two blocks. The Ogrid should look like the other two Ogrids, which you can see in the attached pictures. But the Ogrids are constructed outside of the blocks and they get into the other blocks surrounding the Ogrid. You can see it in the attached pictures, too. Normally they shoud be construckted inside the block you want to split for the Ogrid. I tried everything to solve the problem which I had in my mind. But no way solved the problem.
Do you have any ideas? Many thanks for your help!
Best regards
Fred_Erik
Fred_Erik is offline   Reply With Quote
Old   May 15, 2014, 22:19
Ok, solved problem by myself. Sry. :-)
Old   August 6, 2017, 12:43
Pawel Zdunek is on a distinguished road
I've got the same problem, what helped in your case?
Pawel Zdunek is offline   Reply With Quote
Old   August 7, 2017, 04:39
Sebastian Engel
bluebase will become famous soon enough
Hi Pawal,
in the original problem the verticies where - for some reason - moved outside of the original block.
These vertices could simple be moved back inside, which probably solved the problem of Fred.
Check whether the new created blocks are still connected in the right order. Maybe you can also move them to a right location to get a valid blocking. Also, check whether you had the option "create around" active when you generated the ogrid.
With regards,
Sebastian
bluebase is offline   Reply With Quote
icem, ogrid
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 Hengel OpenFOAM Meshing & Mesh Conversion 7 November 15, 2021 23:56
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 Hengel OpenFOAM Meshing & Mesh Conversion 0 September 15, 2010 09:34
[ICEM] Hexa to Sweep block conversion pertupd ANSYS Meshing & Geometry 1 June 19, 2010 22:37
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
