need help in meshing of volume inside volume
Old   May 1, 2014, 09:59
Post need help in meshing of volume inside volume
mehaque101's Avatar
Haq
mehaque101 is on a distinguished road
I am relatively new to CFD . I am trying to mesh a no-frost refrigerator. After making the geometry of the entire refrigerator in DM, without the shelves, I have drawn out fluid domain. Now when I mesh and go for named selection for boundary condition I can not get access to the inlet outlet ducts for air flow to the refrigerator section from the freezer section. My entire geometry is just one part. This is because my ducts are inside the two sections of refrigerator. I would appreciate any help in this matter.
mehaque101 is offline   Reply With Quote
Old   May 1, 2014, 10:42
Maaz Ul Mosaid
maazulmosaid is on a distinguished road
supress the outer body and then dry...
just a suggestion from amateur
maazulmosaid is offline   Reply With Quote
Old   May 1, 2014, 21:00
Arrow
mehaque101's Avatar
Haq
Thanks Maaz for your quick reply.
As I said I have the entire geometry as one part. If I don't have it as one part then I can not get fluid domain drawn from the geometry, or if I have separate bodies then fluid domain will be in two or more body. In that case the boundary conditions will become a problem. I have used fill (cavity) to get the fluid domain.
Any other suggestions?
boundary conditions, design modeler, mesh 3d
Fire and smoke modeling CFDST CFX 84 April 30, 2019 08:01
Solidworks, inside volume AdidaKK Main CFD Forum 7 August 12, 2009 16:37
Meshing Volume in Gambit for a water turbine Zaqie FLUENT 1 July 24, 2009 02:25
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
