[ANSYS Meshing] Meshing on ICEM or ANSYS?
Old   April 27, 2014, 07:31
Default Meshing on ICEM or ANSYS?
Hashem M. Al Argha
HashemAlArgha is on a distinguished road
I hope you are all doing well!
I am working on my senior project and I am required to do analysis on a 3D model of our plane, everything was going fine until i reached the meshing part it was a mess..
I tried the usual way of making an enclosure then subtracting the model then when I go to the meshing part I get errors all over..
Shall I post the error page here? or shall I stop using the ANSYS mesher and start using ICEM?
Thanks!
HashemAlArgha is offline   Reply With Quote
Old   April 27, 2014, 11:27
Alex
Kina is on a distinguished road
Actually, it depends on the type of mesh you want to achieve and the type of errors you get so it wouldn't be the worst idea to let us know!
Kina is offline   Reply With Quote
Old   April 27, 2014, 14:08
Hashem M. Al Argha
Well my aim from this simulation is to find the Lift and drag for the model at different pitch angles. Drag coefficient (CD), induced drag, Re#, magnitude of the velocity in the symmetry plane, Recirculation zones, finding the Boundary layers,, etc..
The only time I touched meshing was on a 2D airfoil and it was auto generated ,, today I did a tutorial on ICEM 14.0 CFD (this one http://home.cc.umanitoba.ca/~engsjo/...duct-v1p01.pdf) so yeah,, now I know basics of ICEM, what's the next step..
So basically what I want to say is that I am still a noob and I don't know which mesh type/ error I should use,,
Old   April 27, 2014, 14:43
Hashem M. Al Argha
So here are my files.. https://www.dropbox.com/s/7vaws411jkwf7xv/Last_CFD.zip
I don't want someone to do it for me I want to learn!
Thanks!
Old   April 27, 2014, 17:59
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Similar case is discussed here:
http://www.cfd-online.com/Forums/ans...m-meshing.html
Far is offline   Reply With Quote
Old   April 28, 2014, 03:12
Hashem M. Al Argha
So basically after 7 hours of watching tutorials and trying to mesh this, I reached nowhere! (just created four blocks around my model).
The thing is most tutorials don't tell you why this step is there, or why we do this and that.. Also, when there is a slight difference between the tutorial and my model I fail to improvise..
Far could you help me and take a look at my files?
Thanks!
Old   April 28, 2014, 12:25
kad
kad will become famous soon enoughkad will become famous soon enough
First start off with a good CAD model. Your models has problems in the region of the trailing edge. The lower wing surface wraps around the trailing edge. Further the trailing edge curve is missing and the geometry is not captured very well in this region in general (see att4). This might be caused by wrong model/triangulation tolerances in ICEM or CAD programm. Correcting this will make blocking much easier.
kad is offline   Reply With Quote
Old   April 29, 2014, 15:55
Hashem M. Al Argha
Thanks kad!
I had to change my airfoils to non reflex airfoils, the mesh was fine, generated using ansys, here are my results https://www.dropbox.com/s/fah02t03jw...20Results.docx
(I followed the Ahmad's car tutorial)
I will go back to reflex airfoils and fix the trailing edge and if I need any help I let you guys know ..
Thanks!
[ICEM] ICEM incapable of writing ANSYS input mesh with midside nodes ampa ANSYS Meshing & Geometry 0 April 24, 2013 06:23
[ANSYS Meshing] Issues in exporting mesh from Meshing to ICEM CFD sihaqqi ANSYS Meshing & Geometry 5 March 5, 2013 03:40
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing Far ANSYS Meshing & Geometry 0 March 3, 2013 11:17
[ANSYS Meshing] How to pop the hood on ANSYS Meshing to access ICEM CFD... PSYMN ANSYS Meshing & Geometry 3 October 4, 2012 20:41
Ansys icem meshing of 2d hill syler3321 Main CFD Forum 0 June 27, 2010 22:38
