[Other] BladeGen Data Import Wizard
Old   April 26, 2014, 07:14
Default BladeGen Data Import Wizard
kariz is on a distinguished road
dear all
I'm trying to import geometry into BladeGen using Data Import Wizard.
During the process I have an error in "Step 4-Blade Geometry, Edit/Confirm Blade Loops". How can I the the error in this step?
'Error: Selected Item is not available. Please complete ...'
kariz is offline   Reply With Quote
Old   April 26, 2014, 10:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
which method you are using? IGES file or data points?
Far is offline   Reply With Quote
Old   August 5, 2014, 22:46
Ahmad
Ahmad_AA is on a distinguished road
I used data points and I have the same problem
Ahmad_AA is offline   Reply With Quote
Old   August 11, 2014, 08:46
Ludvik is on a distinguished road
Do you have in Step2 all marks as green tag? How many blade layers do you have?
Ludvik is offline   Reply With Quote
Old   August 11, 2014, 20:18
Ahmad
Hi Ludvik thanks for your response. Yes I have everything in green. It turns out that I had two bad point in my meridonal contours but I fixed them. However, now I have a new problem! The data import wizard crashes when I complete the steps and hit the complete button. I have 19 blade layers, any ideas would be so much appreciated!
Old   August 12, 2014, 07:44
Try export the blade without any LE/TE elliptic ratio.
Old   May 27, 2015, 14:39
beyonder
beyonder1 is on a distinguished road
I am also getting the same problem of 'wizard crash' after completing the steps. If you have found the solution, could you share it.
beyonder1 is offline   Reply With Quote
Old   July 11, 2016, 12:07
Brett
Bdew8556 is on a distinguished road
Hey guys im having this problem.
How did you fix the issues with Step 4?
Brett
Bdew8556 is offline   Reply With Quote
Old   July 11, 2016, 12:11
Brett
Heres my image
Old   August 28, 2018, 16:07
Charles
cdelorenzo is on a distinguished road
Hi all,
This is my first post, so I apologize for missing any information in my request.
I am having the same problem on Step 4. I have been able to select two curves each defining the shroud and hub curves. I have also selected a series of curves to define the blade objects. One of the objects is four curves (to make a closed loop) and the other is 9 curves (again, to make a closed loop). For some reason, the original .iges file I am working with imported one of the blade loops as more than four curves. This is shown in the attached image as the series of points and lines near the lower right hand corner of the GUI. The blade object with four curves is orthogonal to the image and is not shown.
Specifically, my question is does the blade profile need to be defined by four curves? Secondly, if this is the case, can these lines easily be combined? Thirdly, should each blade object/loop be selected separately in step 2? I am not sure if this is an option or not, since all the objects seem to be lumped into one curve set.
Thanks in advance for any help offered!
-Charles
cdelorenzo is offline   Reply With Quote
[Other] [DesignModeler] import data XYZ zelito ANSYS Meshing & Geometry 0 December 15, 2009 15:48
Import validation data to CFX Post Vattenkraft CFX 0 November 26, 2009 20:55
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
import spline data format Chris Siemens 0 March 30, 2005 14:09
I-DEAS CAD data import with boundary conditions Yunus Siemens 1 June 1, 2001 11:04
