April 24, 2014, 16:15 |
Meshing a Cylinder
anup radhakrishnan
Rep Power: 12 |
Can any one please advise on how to create a structured mesh for a cylinder in Ansys? The problem I am facing is at the top and bottom faces. I am trying to simulate the flow past a finite 3D cylinder with a volume of water above it. I have meshed this volume as a structured mesh corresponding to the fluid domain around the cylinder. The domain around the cylinder is modelled as a block with a hole in it. This necessitates the addition of a cylinder above the hole to capture the mesh effectively. Is this the right approach to meshing these kind of problems? I have attached a few pics of the same. thanks, Anup bottom domain.jpg top domain.jpg |
April 28, 2014, 12:58 |
Alex
Rep Power: 49 |
If you want a pure hex mesh, you can further divide the cylindrical volume above the cylinder to get volume elements with hexahedral shape.
top domain.jpg |
December 9, 2014, 13:32 |
Scott Telford
What method did you use for this? |
[ICEM] Meshing of 2D cylinder / number of nodes | leonidassr | ANSYS Meshing & Geometry | 4 | September 23, 2013 07:08 |
[GAMBIT] structured Meshing cylinder and airfoil NASA 0012 | wesam | ANSYS Meshing & Geometry | 2 | October 1, 2012 15:33 |
[blockMesh] meshing a cylinder | Nico A. | OpenFOAM Meshing & Mesh Conversion | 0 | April 7, 2011 12:09 |
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder | nammari | OpenFOAM Meshing & Mesh Conversion | 5 | March 11, 2011 20:49 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
