[DesignModeler] how to find mid-edge/mid-surface between two successive turbine blade |
April 16, 2014, 23:29 |
Mohsen Modir Shanechi
Hi guys,
First please find attached a picture of my problem. I just imported geometry from Solidedge into Ansys designmodeler 15. Now I want to specify and sketch a line/edge or surface exactly between two successive blades in order to define flow region and apply periodic boundary. As it is depicted in attachment. the thing is I tried mid surface but it didnt work out. Have you got any solution for that ?! Cheers |
mid-surface, periodic boundary |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Hexa meshing of Wind Turbine blade. Help for Newbie please | federvo.mala | ANSYS Meshing & Geometry | 4 | June 8, 2013 03:19 |
force acting on gas turbine blade.... | vvj | Main CFD Forum | 1 | March 3, 2010 01:04 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
help to find torque of a wind turbine using fluent | athiyaman.p | FLUENT | 1 | March 10, 2006 10:49 |
