April 1, 2014, 05:46 |
Ansys 15.0 cad interface
Ndong-Mefane Stephane Boris
Rep Power: 12 |
I've been using Ansys 14.5 coupled to CREO2.0 without any problem. just moved to 15.0, and impossible to configure the interface plugin (I followed ALL the instructions on the ANSYS customer portal...) is it only me, the CREO2.0 plugin does not work anymore in ANSYS 15.0???? |
April 1, 2014, 12:25 |
I have recently configured solid works for ansys 15.0 and it is working fine. I guess it should also work for creo. Check the supported version info on ansys website. Also try to reinstall ansys. If it does not work, downloaded ansys setup again and reinstall ansys.
April 3, 2014, 22:53 |
Problem Fixed
Rep Power: 12 |
I just needed to re-install CREO Parametric...
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Ansys 12.1 - Create Rotor/Stator Interface for Fluent | opm | ANSYS Meshing & Geometry | 21 | May 23, 2016 08:29 |
Modelling valves/orifices using interface models | DarrenC | CFX | 5 | June 3, 2014 06:14 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
