[ICEM] Delaunay Problem
Old   March 19, 2014, 12:42
Default Delaunay Problem
Edoardo
gigiboumba is on a distinguished road
Dear user,
I am relatively new to ICEM.
My project is about meshing a wind turbine: it consists of a spherical flow field around that contains the whole assembly, with a cylindrical one around the rotor only.
I meshed the assembly with robust octree as first. This meshed the geometry fine, expect for some little element on the trailing edge which I manually moved in the correct position. To move them I deleted all the volume elements and then moved them.
Then to reconstruct the volume mesh from the surface mesh I used the quick Delaunay. The mesh botained mesh, however, isn't what I would like: ICEM makes a block around my domain and the element are very weird. I will put a picture of it.
If anyone has an input it would be great!
Thanks a lot!
Last edited by Far; March 20, 2014 at 12:01. Reason: Was just adding image at the end of the post to clarify the problem
gigiboumba is offline   Reply With Quote
delaunay, mesh, mesh problem
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
