[ICEM] Meshing of a cylinder containing a small hole on one face
Old   March 9, 2014, 07:39
Post Meshing of a cylinder containing a small hole on one face
Giovanni
Giova82 is on a distinguished road
Hello people,
I am new to ICEM and I am facing the following problem: I have to mesh a cylinder with a small opening at one face in order to simulate a bubble column
within an air-lifting reactor. In order to do that, I created a big cylinder and small circle near one of the two faces. Afterwards, I projected the circle on one of the faces of the cylinder, then I trimmed the big face with the projected circle, and finally I created two surfaces.
I did all the tutorials of the tutorial manual but I have still no idea how to do that . I would like to create a structured mesh if it is possible. The dimensions of the big cylinder are: Height 50 cm, Diameter 5 cm. The diameter of the small circle is 1 mm. I do not think that it is difficult, but I don't know how to do that.
Can anybody help me?
Giova82 is offline   Reply With Quote
Old   August 12, 2015, 07:49
surya
surya.tdr is on a distinguished road
if you have solved this problem can you explain
surya.tdr is offline   Reply With Quote
cylinder structured mesh
[ANSYS Meshing] Mapped Face meshing Thermal_engg ANSYS Meshing & Geometry 4 June 5, 2013 06:37
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 15:37
small cylinder and big cylinder Eric CFX 1 January 26, 2007 06:38
