March 7, 2014, 03:16 |
Hybrid Mesh: Free Block
Hey,
I'm working on a project in which I have to hybrid mesh a difficult geometry. Therefore I tried to use several hybrid meshing techniques for simplier problems, just to see which method would be best for the problem. But here I had some issues (I tried the hybrid mesh via free blocks): First of all I blocked all my geometry. Then I set the type of the blocks, that should be tets later, to free (Picture 1). Here some strange things appeared and the meshing was not shown correctly (Picture 2). After I set "3D free block mesh type" to e.g. hexa-core for these 3 blocks, "cut plane" shows s.th. like this (Picture 3). I hope somebody can help me and tell me what to do, what I forgot to do. Otherwise I have to try the "regular" hybrid meshing way like in the tutorial. Thanks a lot Flo |
March 20, 2014, 06:30 |
REASON OF PROBLEM FOUND!
Hey there, I finally found the reason of my problem. I was using more than 1 processor for meshing. So when switching more than one block to free (e.g. 3 blocks), with multiple processors in usage, there is an error in your unix-konsole saying "2 of 3 unstructured volumes did not mesh". So as I conclude, it isn't possible to work with more than one processor when you want to switch more than one block to free. But after all it would be interesting to solve the major problem, so that usage of more processors is possible in this case. Best wishes Flo |
September 7, 2014, 07:59 |
srr
Rep Power: 16 |
Hey meshflo
Brilliant finding, was struggling with it for a while, now it works smoothly. Thanks for sharing SRR |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] How to do 2D hybrid mesh around hydrofoil | jaber | FLUENT | 1 | January 3, 2013 12:33 |
[ICEM] How to do 2D hybrid mesh around hydrofoil | jaber | Main CFD Forum | 0 | January 3, 2013 12:17 |
[ICEM] How to do 2D hybrid mesh around hydrofoil | jaber | ANSYS Meshing & Geometry | 0 | January 3, 2013 12:09 |
