[ICEM] 2D Tri/prism mesh around zero-thickness curve (sail)
Old   March 3, 2014, 10:34
Default 2D Tri/prism mesh around zero-thickness curve (sail)
Gerry Boyce
GBNB is on a distinguished road
Hi there, I am trying to mesh a single curve (analogous to a single skin sail) in ICEM. The curve is similar in shape to one half of a 2D symmetric airfoil. I have managed to create a tri mesh using the Curve Mesh Setup and patch independent surface mesher but I can't seem to use the Blayer functionality to create finer prism/quad cells along the curve. Does anyone have any ideas on how to do this?
Thank you!
GBNB is offline   Reply With Quote
Old   March 4, 2014, 10:40
Gerry Boyce
I don't think it can be done, curve needs to be a closed loop for Blayer2D to function. I only found this thread now, apologies for the repost:
http://www.cfd-online.com/Forums/ans...ary-layer.html
Old   April 3, 2014, 12:42
Default More info
Gerry Boyce
See Psymn's last two posts
http://www.cfd-online.com/Forums/ans...uded-mesh.html
2d mesh, blayer, sail, zero-thickness curve
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[ICEM] how to mesh a sail (and the rest of the boat) matteoL ANSYS Meshing & Geometry 4 May 7, 2012 11:23
