[ICEM] Dependent Mesh not working
Old   March 1, 2014, 20:45
Default Dependent Mesh not working
LOTFI OULD ROUIS
zomayabssa is on a distinguished road
Hi people,
I am realizing a simulation around a 2D blade with a thikness. I've meshed the inside blade with Independant All tri mesh and the fluid with a dependant tetra mesh inflated around the blade.
The problem is that the inflation and the inside blade meshing are good but the all tri dependant meshing is really bizarre . (figure.1 and figure.2). Have you even got this problem guys?
I would really apreciate anyone's suggestion for that issue.
Thanks a lot,
Ruis
zomayabssa is offline   Reply With Quote
Old   March 7, 2014, 11:03
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Hi friend firs of all, I particular question, why did you decide to work with tetra next to the Wall?? because in contrast is always required to worh with hexa or quad mesh type next to the Wall...
This type of error is because you domain has holes or it is poor defined. Patch based (dependent) work with curve sizes while patch independent use surface size...
If you solve this issue please hsare your approach!!
juliom is offline   Reply With Quote
Old   March 7, 2014, 13:24
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
what is stopping you from a blocking ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 9, 2014, 11:29
LOTFI OULD ROUIS
Thanks for your suggestions guys:
1- @Juliom: Yes I'm working with Hexa near to the wall as you can see from Figure.2 of my last post. If you're refering to the blue mesh, it only represents the thickness of the blade. So the near Wall is right after the blue mesh.
2- @diamondx: What do you mean by blicking? Do you mean a manual Hexa Meshing? Actually I've chosen this type of meshing because it alllows me to inflate the blade profile layer and keep a coarse mesh far from the wall.
Tank you,
Regards,
Loffy
2d meshing, inflation, strange, tetra, tri
[ICEM] Patch dependent surface mesh problem! hadikhayyamian ANSYS Meshing & Geometry 14 January 27, 2018 09:47
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
Mesh interfaces and reactions in porous media - why not working? RossFS FLUENT 0 December 15, 2013 06:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
