[ANSYS Meshing] Ansys 15 Parallel Meshing?
Old   February 27, 2014, 00:50
Default Ansys 15 Parallel Meshing?
Rob Muggleton
robmuggleton is on a distinguished road
Hi All
I have googled and googled but I cannot get parallel meshing to work. I have HPC license and ansys 15. I am meshing a 2d model, tried quad and tri, but it only uses 1 process. I have enabled 8 processors, then tried 4 processes (you know, i7 4800MQ has 4 cores 8 threads thing), but wont do it...
Any help much appreciated. I have got GPU acceleration to work on the couples pressure solver though nicely, but it wont do it for SIMPLE or SIMPLEC methods... All the documentation says pressure based solvers, so it should do it for SIMPLE and SIMPLEC as well i would have thought?
Thanks
robmuggleton is offline   Reply With Quote
Old   March 6, 2014, 11:08
vidyanand
Vidyanand Kesti is on a distinguished road
Good i am also waiting from ANSYS,
this mesh method work when your bodies are separated each other created 10 bodies, in different part in Design modeller means no mesh connectivity then it worked fine, but if I am using the 3-different parts with interface then it’s not working
Vidyanand Kesti is offline   Reply With Quote
ansys 15, parallel meshing
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 10:48
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 23:04
Parallel Meshing in ANSYS 13 makkks ANSYS Meshing & Geometry 1 September 5, 2011 13:34
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 21:03
ANSYS meshing help s.garg ANSYS 1 November 12, 2010 05:11
