[GAMBIT] Different of union, split, and subtract |
February 20, 2014, 22:03 |
#21 |
Erlanda Pane
Rep Power: 12 |
Yes, The porous zone-0 has thickness 7 cm.
February 21, 2014, 01:42 |
#22 |
Maxime Perelli
Rep Power: 41 |
then you have to build also this volume
In memory of my friend Hervé: CFD engineer & freerider |
February 21, 2014, 03:32 |
#23 |
Erlanda Pane
Rep Power: 12 |
Hmmm, volume 2 is porous zone.
How to connect between volume 1 and volume 2 ? Thank you. |
February 21, 2014, 03:37 |
#24 |
Maxime Perelli
Rep Power: 41 |
I understood volume 2 is fluid, and you need a third volume
February 21, 2014, 03:51 |
#25 |
Erlanda Pane
Rep Power: 12 |
Hmmm, Iam sorry.
When I finished to build thrid volume, Aftet that, which menu in gambit (union,split, or substract) to connect them? Thank you. |
February 21, 2014, 04:06 |
#26 |
Maxime Perelli
Rep Power: 41 |
if volume 1 is fluid
if volume 2 is fluid if volume 3 is porous then you have to connect all surfaces you can provide me your dbs file once porous volume is done
February 21, 2014, 06:07 |
#27 |
Erlanda Pane
Rep Power: 12 |
Voume 1 is fluid, and volume 2 is porous
This is my dbs file. Thank you |
February 21, 2014, 06:12 |
#28 |
Maxime Perelli
Rep Power: 41 |
ok now I understand
Split volume 1 with volume 2 (option "retain" disabled) That's it
February 21, 2014, 09:15 |
#29 |
Erlanda Pane
Rep Power: 12 |
Okay Max, thank's for your help.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[GAMBIT] Problem with split option | akshayygarg | ANSYS Meshing & Geometry | 29 | March 25, 2014 01:00 |
