[DesignModeler] Meshing Aerofoil Workbench (Design Modeller)
Old   February 15, 2014, 14:37
Default Meshing Aerofoil Workbench (Design Modeller)
Eleanor Rajaratnam
elebelly is on a distinguished road
Hi, I'm currently trying to mesh for the FX 74-Cl5-140MOD aerofoil on workbench, however when I try to add 'Surfaces from edges' I get the error 'Some selected edges failed to form closed loops'. I've tried editing the .txt file and splitting the curve however I just cant seem to bypass this problem!
Any help would be truly appreciated.
Kind regards,
Ele
elebelly is offline   Reply With Quote
Old   February 15, 2014, 15:03
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
How exactly did you try to edit the file?
Did you repeat the first point at the end of the file? That usually helps.
flotus1 is offline   Reply With Quote
Old   February 15, 2014, 15:56
Eleanor Rajaratnam
Hi! Thanks so much for your reply but I realised that I should have had the last point number as 0!! Rookie mistake.
[ANSYS Meshing] Workbench Meshing Tool - Max Face Size Parameter MaxHeat ANSYS Meshing & Geometry 3 March 2, 2021 08:50
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
[ICEM] Icem cfd aerofoil meshing cfd seeker ANSYS Meshing & Geometry 9 February 8, 2012 21:39
CFX meshing with Workbench anna CFX 1 December 19, 2006 15:35
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
