[Workbench] geometry
Old   February 6, 2014, 05:37
Default geometry
annu is on a distinguished road
hi friends,
Kindly tell me how to make 1000 m cylinder in ansys 13? Is there any limit?
your response is truly welcome..
annu is offline   Reply With Quote
Old   February 6, 2014, 12:52
Alex
Kina is on a distinguished road
I am not sure if there are any restrictions in WB13. Have you tried to build a smaller cylinder and then scale it up with a body operation?
Kina is offline   Reply With Quote
Old   February 7, 2014, 01:58
Sixkillers is on a distinguished road
When you are launching a new DesignModeler session just toggle on Enable large model support:
Cheers
Sixkillers is offline   Reply With Quote
Old   May 1, 2014, 08:54
yep i did kina but as told by six killer, its now possible..
Old   May 3, 2014, 09:44
one more problem is arising, i cant split circle with rectangle in ansys 13. boolean option is not coming. i have to make 3d geometry.
Old   May 3, 2014, 09:45
Cheers
thankyou..
Old   May 3, 2014, 10:11
Alex
What's the error message? Have you set your tool body to 'add frozen'?
I guess it's also possible when you set your body you wanna cut to 'add material' and the tool body to 'cut material'.
Old   May 4, 2014, 11:55
thanku again, its splitted
one more question, how to make a square shaped hole at surface in the middle of geometry?
Old   May 4, 2014, 12:31
Alex
What do you mean by "square shaped hole at surface"? so you don't want a real hole, but just something you can assign boundary conditions to? Then you should draw the sketch for your square, extrude the sketch and set it to "imprint faces" instead of add anything. That should work. Otherwise, you can also extrude it a little and then choose "project to surface" from the workbench tools. Then, you just suppress the extrude in your flow calculation.
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 06:14
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 20:51
[GAMBIT] import terrain geometry cfdworker ANSYS Meshing & Geometry 2 May 24, 2009 22:40
