January 29, 2014, 17:16 |
Blade Leading Edge
diego flores
Rep Power: 17 |
Hi Everyone,
I'm working on the meshing of a blade compressor (stator). I'm using the C-Grid strategy. However I have issues to associate the mesh to the Leading Edge surface. I did the association with edges and this kind of association inflates the mesh and there is no association with the real geometry. How can I fix the association? Thanks in advance |
February 2, 2014, 15:15 |
Sorry this picture is not enough, would you kindly attach more pictures? , or if you can share the files. |
February 4, 2014, 05:53 |
diego flores
Rep Power: 17 |
Hi Mezah, thanks for asking.
Here I upload some extra images. IN the First one I show a part of the leading edge of the blade. In the next one I show you how the mesh is distort when I mesh with Faces Projection, although the mesh follow the leading edge geometry the distortion is evident. In the third one I show you how the mesh follow the geometry with face projection but in fourth image I change to Edges Projection and the distortion dissapear but there is an inflation and the mesh does not follow the Leading Edge geometry. I attached the geometry files: http://www.file-upload.net/download-...ject2.blk.html http://www.file-upload.net/download-...ject2.prj.html http://www.file-upload.net/download-...ject2.tin.html Thanks in advance |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Ansys CFX Turbogrid, Problem with blade leading edge sitting on hub at inlet | Irondome | CFX | 9 | August 18, 2016 19:56 |
Unusual turning angle ahead of blade leading edge | carnage2121 | Main CFD Forum | 0 | May 20, 2013 20:11 |
Y-Plus values at aerofoil leading edge and trailing edge at high incidence | Engr07 | Main CFD Forum | 4 | June 29, 2012 11:42 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
