[ICEM] Interface separating 2 Domains in ICEM for Fluent
Old   January 23, 2014, 23:37
Default Interface separating 2 Domains in ICEM for Fluent
ant
antornado is on a distinguished road
Hi experts,
I am currently working on simulating fluid flow across a centrifugal compressor. My question is regarding the interface that separates the 2 different domains shown in attachment photo.
1) For the first domain, it is for simulating flow through a moving impeller. I have the surface marked in 'Orange' and add to part as 'Impeller'. I also created material body inside marked in green as 'Impeller_body'.
2) For the second domain, it is for simulating flow through a stationary diffuser. I have the surface marked in 'blue' and add to part as 'Diffuser'. I also created material body inside marked in yellow as 'Diffuser_body'.
3. As for the surface that separates the 'Impeller' and 'Diffuser' Body, I marked it in 'black' and and add to part as 'Interface'.
I then generate an unstructured mesh. Is this the correct way of handling 2 different domains and the single interface that separates them?
Next, I then import the mesh into Fluent and I received errors during mesh check as shown in attachment photo 2.
1) I would like to ask why is there 3 interfaces to select in the selection box. Shouldn't there be only 2 since I created only 2 different material points in ICEM? Or is it due to the added interface surface as 'Interface' in ICEM? Please advise me on this
Also, I tried to link the 2 'interface 002' and 'interface 003' together. This is the problem I have:
2) Error message indicates that I have unassigned interface zone detected, and advise I add periodicity. Did I miss any step out previously?
Im doing this as a final year project in university. Any advise with elaboration will be of great help. Thank you!
regards,
ant
antornado is offline   Reply With Quote
ICEM tet-tet interface not meshed and problems when meshing in segments Catthan ANSYS Meshing & Geometry 0 October 27, 2011 07:12
interface with different sector domains Babu Venkat Main CFD Forum 1 June 26, 2006 07:59
Interface from ICEM to AVBP?? Lee Main CFD Forum 0 October 2, 2005 10:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
