Meshing of sphere shape
Old   January 22, 2014, 12:19
Default Meshing of sphere shape
Michael
mhkennedy is on a distinguished road
How did you associate to the hemisphere surface, I have managed to mesh a full sphere by using associate face to surface however this does not work with the hemisphere?
mhkennedy is offline   Reply With Quote
Old   January 22, 2014, 15:21
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
show some pics please...
Far is offline   Reply With Quote
Old   January 23, 2014, 09:34
Default Hemisphere Associates
Michael
here is a picture of the sphere
Old   January 23, 2014, 10:10
Far
Sijal
first associate the edge tu curves on ground.
Then hide the all other surface except sphere.
Use index blocking and only choose the block surrounding the sphere.
Change material of the block inside sphere to solid or delete it(you have just made it visible in last step using index blocking)
Go to association panel again and snap vertices. you can move vertices on the sphere surface if you want to optimize the mesh.
To create ogrid around sphere select the block inside sphere (solid) and select option around and also select face on the ground.
Old   January 23, 2014, 10:43
Far
Sijal
Can you please post this question in ANSYS Meshing forum.
[ANSYS Meshing] Structured Volumetric Meshing in Workbench for a Sphere AS_Aero ANSYS Meshing & Geometry 0 March 19, 2013 07:28
[ICEM] meshing a sphere - large deviation from perfect sphere murx ANSYS Meshing & Geometry 25 August 15, 2012 13:37
[snappyHexMesh] Meshing a sphere with snappyHexMesh Cyberholmes OpenFOAM Meshing & Mesh Conversion 2 July 19, 2011 17:46
Meshing a sphere using ICEM lost.identity ANSYS Meshing & Geometry 1 March 13, 2011 21:19
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
