January 22, 2014, 06:42 |
Boolean issue
lauda
Rep Power: 12 |
Hi there,
I'm simply trying to generate a solid volume starting from a cad file. It's a radial blade. When I import the cad file in Blademodeler there are 3 faces while hub and tip surfaces are missing. I generate those and check that the normal to the faces are correct. I'd like to create a solid volume by uniting the 5 surfaces using Boolean. What I obtain however is one solid body with a certain surface but zero volume.. is Boolean the wrong tool in this case? or should I ask to modify the CAD file in order to generate a volume body? Thanks |
Fluent does not launch from workbench | NickyNac | FLUENT | 8 | April 13, 2018 10:42 |
FLUENT not running | CFDFRED | ANSYS | 5 | April 20, 2017 01:53 |
[ansys fluent] problems of running ANSYS 12.1 fluent module | mkwang2006 | FLUENT | 3 | September 30, 2013 11:59 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 07:44 |
Info message -> Fluent does not start | Jenson | FLUENT | 0 | December 22, 2011 18:21 |
